PC banking not working
Dario
Re: PC banking not working
Post by Dario »
Thanks Aka for the support, I tried the version but it still does not work ...
the card is queried but windows says that there are no valid certificates.
I am available for any test
Test results "still does not work" and "no valid certificates" are useless. Give me as much information as you can.
Read carefully: https://wtware.com/logs.html There are no instruction "cut five lines of log".
And screenshots with problem: in wtware and the same screen in mstsc.exe.
Dario
Post by Dario »
OK!
Attached the log and screenshots.
This is a smartcard (https://www.pec.it/smart-card-formato-c ... edito.aspx) for digital file signature
Thanks for the support
Dario
(124.5 KiB) Downloaded 2012 times
Dario
Post by Dario »
The attachment after_login_scard.jpg is no longer available
Dario
Post by Dario »
Dario
Post by Dario »
Good morning, do you need more details to analyze the problem?
Try wtware 5.8.2. And please, read carefully: https://wtware.com/docs5/logs.html Especially paragraph 4: "Make as few actions as possible".
