PXE boot not working
WTware network boot ways - bootable floppy, DOS, PXE-loaders, BootROM chips.
fedora
Post by fedora »
I'm trying to use a RB Pi 2 to boot through network, but it is not working, I setup DHCP, TFTP on WTware Center, it works, gets the IP address, find the TFTP and it downloads the wtware.pxe file, but it shows the message "CACHE: Misaligned operation at range [01000000, 01003f9a] Bad LINUX ARM zImage magic!"
What's wrong?
PS: If I boot the system through the SD card it works fine! I'm able to connect to terminal server, the problem just happens through PXE boot.
Raspberry boot
Re: PXE boot not working
Do not write "5.4.40\wtware.pxe". Doubleclick on 067 line and check server autodetection.
If you reeeealy want to specify value, put "5.4.40\kernel7.img" here.
Dodavid
Post by Dodavid »
i have the same problem, but I only get the message Bad Linux ARM zImage magic!
Did you try the same solution for the same problem?
