Dlink DWA 127 USB Wifi Antenna compatible? [SOLVED]
seto
Post by seto »
I'm using RPi3 with WTware 5.4.68 with internal wifi interface but the signal is weak in some places. So I'm asking, how to use a different wifi interface ?
I tried to plug a D-link DWA-127 which is using mt7601u driver in debian jessie. Is it possible to configure WTware to use this interface instead of the internal one ?
Thanks for your help and great job btw.
Regards,
Sebatien
Re: Dlink DWA 127 USB Wifi Antenna compatible?
Connect new wifi device, boot (with ethernet or internal wifi, we need network for logging) raspberry and make a log: https://wtware.com/logs.html
seto
Post by seto »
Please find the log file attached to this reply :)
So you will see :
11-27-34-658| [ initrd] [ 11.767483] USB: 2001:3d04 D-Link Corp.
Thanks for your help....
WTware_B8.27.EB.7B.BB.8E_2017-03-14_11-27-42.txt
(66.37 KiB) Downloaded 1165 times
Please, try wtware 5.4.82.
seto
Post by seto »
Same issue with 5.4.82
See the logs below.
Thanks !
WTware_B8.27.EB.D1.C7.77_2017-03-23_14-42-21.txt
(86.95 KiB) Downloaded 1144 times
And 5.4.84.
seto
Post by seto »
Now I get this (attached picture)
This is appening when starting wifi drivers.
Regards,
Ups...
From command line type:
cat /tmp/all.log
Press Enter.
Take a photo.
Press Shift-PageUp.
Photo.
Repeat "Press Shift-PageUp. Photo." three times.
seto
Post by seto »
I'm using 5.4.90, and still getting trouble. You can see in attached file.
Please, try wtware 5.4.92.
seto
Post by seto »
Resolved !
