RDS Devices CAL error with WTware
vincny
Post by vincny »
I like enquire anyone using WTware with RDS Devices CAL and is working properly. I keep getting Event ID 1004 telling me:
"The Remote Desktop Session Host server cannot issue a client license. It was unable to issue the license due to a changed (mismatched) client license, insufficient memory, or an internal error. Further details for this problem may have been reported at the client's computer."
I have no problem with User CAL but it was not the right license to apply for the VDI function.
Re: RDS Devices CAL error with WTware
Does it work well with mstsc.exe?
Do you get the same error with other wtware terminals?
http://wtware.com/logs.html
vincny
Post by vincny »
Thanks for the reply, yes it is working on Windows Machine I am able to receive the Devices CAL license.
All the Raspberry device on WTware software are not getting the Device CAL license. With Event Error 1004 mention. :(
Attach is the log capture.
Device-CAL-Licesne-Not-Issue.log
(42.6 KiB) Downloaded 1276 times
There are no errors in the Wtware log you attached. Terminal connects to server.
vincny
Post by vincny »
Hi Akatik,
The connection working now but no license being issue.
I will try again when it generate error from the station.
But I confirm that the error was generated from the terminal server:
vincny wrote:The connection working now but no license being issue.
So it's very userfull, why not?
vincny wrote:But I confirm that the error was generated from the terminal server:
Where did you see this text?
vincny
Post by vincny »
Hi Akatik,
After sometime WTware will prompt cannot connect due to license issue.
The log was capture from windows 2012 R2 RDSH server.
And where's the log?
vincny
Post by vincny »
Hi Akatik,
I have encounter the error again, when I use Device CAL WTware is generating error that license error.
When I use a windows PC the Device CAL license was issue without a problem.
I have read up that a device require to store a hardware certificate on the device it self is that missing on WTware software?
WTware error - license_error_wtware2
Windows Server error - RDS_Device_CAL license_Error
Please, save the log when you see error message on client screen. Not after client reboot. Not from another client.
