I am using wtware on FitPC2 through network boot. Everything works fine except the errormessage on startup
ACPI Error: Could not enable Powerbutton event
followed by a linux file path.
To turn off the machines I need to power them off with the switch on the device. ESC-Button on keyboard does not work.
How do I get to power off the machine by keyboard or rid of that error message?
Re: ACPI Error: Could not enable Powerbutton event
Update BIOS and reset it to default values. If it won't help, power control seems broken...
Show me log and I'll remove text from screen https://wtware.com/logs.html
Tried BIOS update on one device with USB. Crashed on start up, seems like device is broken. Attached the log with another device of the same type and problem with original BIOS:
- WTware_00.01.C0.08.A1.CD_2018-01-11_10-33-56.txt
- (211.57 KiB) Downloaded 1144 times
WTware crashed or BIOS update crashed?mickx wrote: Thu Jan 11, 2018 12:34 pm Tried BIOS update on one device with USB. Crashed on start up, seems like device is broken.
Pleeeease, make log with recent WTware version. I can not fix old version.mickx wrote: Thu Jan 11, 2018 12:34 pm Attached log with another device of the same type and problem with original BIOS:
BIOS seemed to be crashed on startup with USB stick connected. Long before DOS was stated or I flashed any ROM. Now the screen stays whole black when turning on.
Attached the log with current version.
- WTware_00.01.C0.08.A1.CD_2018-01-11_17-16-48.txt
- (34.36 KiB) Downloaded 1103 times
There is a large button "PRESS here to get log". Press it. Until you do not press "PRESS here to get log" button, there are only TFTP service messages. Not terminal log itself.
Attached the Log from the client. I took this one from the client webinterface.
When I press that "press here to get log from terminal" this button goes grey, the log says "connection from wtc.exe at [server IP]" and nothing else happens. This way I cant find the terminal log.
- WTware 5.6.24.txt
- (76.21 KiB) Downloaded 1072 times
Nice - error message is gone and everything works fine as expected. Many thanks.
