SafeNet eToken (0529:0620)
I have a SafeNet 5110 eToken FIPS (0529:0620) that i redirected via the "smartcard" option on WTWare, i can install the card and the SafeNet Tools inside the VM can access the token just fine, but when i will use the token to sign a executable, it just freezes the signtool, i'll attach the WTWare logs in a zip file (file too large) with "debug" and "debug_pcscd" from the moment i rebooted the thinclient, connected to the vm, and ran the signtool to access the eToken.
- WTware_9C.8E.99.F2.F7.74_2023-06-21_09-05-32.zip
- (69.98 KiB) Downloaded 2389 times
Re: SafeNet eToken (0529:0620)
Log attached.
Not the same machine, but the same model.
Before trying your debug version i tried with 6.2.2 just to confirm it was not a configuration/motherboard/usb port issue, and the signtool freezed again.
With 6.2.3 it worked.
- WTware_C8.CB.B8.2F.CA.85_2023-06-26_15-22-08.zip
- (100.28 KiB) Downloaded 2371 times
pearltorso
Different machine, but identical model.
Before experimenting with your debug version, I opted to test 6.2.2 to definitively rule out any potential configuration, motherboard, or USB port-related issues. Regrettably, the signtool froze once more, reinforcing the notion that the problem lies beyond these variables.
1. Reinstall safenet driver on server.
2. http://wtware.com/logs.html
First step may be important, please do not ignore it.
