wire less connection
Discussions, remarks
elha,
Post by elha, »
any body can help for configuration of wire less connection?
I encountered the following error:
ERROR: Internal error
File: parsserd.ccp
line: 1823
function: processInitrdConfigNetMedia
I entered this lines as Wifi configuration:
#WEP, 64 bit, HEX key, Open System:
#/sbin/iwconfig wlan0 key 1234567890
Re: wire less connection
You start both lines from #? Please, make a photo of screen in wifi configuration editor.
Then, type in command line after error:
iwconfig
And make screen photo again.
elha,
Post by elha, »
Error, after tipping: "iwconfig" in command line.
elha,
Post by elha, »
Wifi Configurations
Nice.
1. First line is not needed.
2. Remove # from second line.
3. Replace wlan0 with eth0 in second line: /sbin/iwconfig eth0 key 9876543210
4. Which wifi card do you use?
elha,
Post by elha, »
Wifi Card:
IEEE802.11b/g Mini-PCI Wireless LAN card
Features:
Support full 32-bit PCI Standard
Support IEEE 802.1b & IEEE 802.11g
Data rate up to 54Mbps
Certificates: FCC/CE/NCC/Telec/Singapore/Malaysia/Thailand
elha,
Post by elha, »
Hi aka,
I sent you a PDF file wich name is Wifi.pdf, by Gmail.
read it please.
HGRIM
Post by HGRIM »
I am getting this exact same error when using 4.6.11. I have tried a static and DHCP IP but the error comes up for both. Is there a reason for this?
Please, try 4.9 wtware version.
