rdp session cross country
Have got any interesting solutions and ideas for problems with terminal servers? Looking for any solution?
smurfjesse
Post by smurfjesse »
hello aka,
do you have some configuration tips or other tips for better perfomance cross country? like the netherlands / germany. we have some trouble with slow pdf and outlook clients.
would like to hear from you!
regards,
jesse
Re: rdp session cross country
To improve graphic perfomance specify rdpcompression=on, bpp=16 parameters and do not enable desktop wallpapers. Is that what you are talking about?
smurfjesse
jup we already did that.
is that realy it?
and how can you check if it is really compresed?
In 2003 server,
1. Open Terminal Services Manager fullscreen maximized.
2. Display session status.
3. Press "Reset Counters".
4. Minimize to tray and maximize window five times. Here is a counters:
without rdpcompression
5. Reset terminal and repeat with rdpcompression=on in config file. Here are counters:
rdpcompression=on
rdpcompression=on
Outgoing is traffic from server to client. The same frames counts mean experiment is quite clean: server sends similar amount of drawing commands both times. With rdpcompression=on we got twice less total bytes and twice less bytes per frame. Do not look at "compression ratio" line, it's another compresion level.
