sd card button on configuration wizard
Movimh
Post by Movimh »
Hi... We read of your project in one of your reply on one of our threads in the forum of raspberry. So, we wanted to try, but we stopped at the beginning ... we installed VTware, but the program is in total crash when we push the button "SD" to create the microsd to boot the raspberry. When we click on it, the window shown in the tutorial appears , but every mouse click freezes the program (Quick format, adjustement on...).
How can we do?
Thanks...
Re: sd card button on configuration wizard
Buttons will be enabled when you will insert SD card.
cschappa
Post by cschappa »
I have tried to format SD with SD card in slot, I'm still getting same error above.
Are you using the last WTware version?
