on raspberry pi 2B when booting from SD with tftp enabled , once I pres F10 to run Config Wizard.
Internal Error
Internal Error
- IMG_20160208_133202-q.jpg (231.71 KiB) Viewed 7995 times
Re: Internal Error
The main error here is Config Wizard on pi 2B. Config Wizard is for x86, it helps to find video driver. On pi 2B there is only one video driver and no need to configure it with Wizard. Please, do not press F10. We'll fix it later.
Run wtware configurator on windows where wtware is installed and tftp service is running. Select pi 2B MAC in list on left side and add something here.
Re: Internal Error
Fixed in 5.4.18.
