When trying to connect to a VNC server using WTware on a RPI3 I'm experiencing an issue where it is not connecting and throwing an "I'm Tired" error indication. The VNC server is definitely running and I'm able to connect to it using a RealVNC from a desktop computer.
The server is running tigervnc-server-1.1.0-18.el6.x86_64 using the following configuration parameters.
VNCSERVERS="1:itvnoc"
VNCSERVERARGS[1]="-geometry 1280x1024 -nolisten tcp"
I've attached my log from the RPI for examination. Am I missing something in the configuration that would cause this failure?
Thanks for your help
VNC Connection Problem
Re: VNC Connection Problem
Please, send log to support@wtware.com Forum does not allow file attachment while you not logged in.
onyxintellect
When I wrote the original post I was logged in and I attached but on well. I've attached it now.
- log.txt
- (26.84 KiB) Downloaded 775 times
