Set Password For config.txt edit
Alon
Post by Alon »
I understand I can manually set it on the RP itself pressing DEL on startup,
How can I set the Password through WtWare Center?
Thank You
Re: Set Password For config.txt edit
This will work only if RPi receives IP and other network settings from our WTware DHCP:
