duri3
Posts: 21 Joined: Tue Nov 07, 2017 6:21 pm
Post
by duri3 » Wed Nov 08, 2017 2:52 pm
Sadly the parameter
isn't working. WTware doesn't show a blue box with the selected Keyboard language. I tried with
and this seems to work, also shows a blue box in the lower right corner with the letters FR-CH.
http://ascii-table.com/keyboard.php/150G-1
Please can you add the de-ch language parameter?
Posts: 972 Joined: Fri Dec 03, 2004 2:05 pm
Post
by aka » Thu Nov 09, 2017 8:14 pm
duri3
Post
by duri3 » Fri Nov 10, 2017 1:11 pm
First thank you for your really fast reply.
Sadly I can't update our RPI Terminal. We do boot wtware from sdcard. The configurator doesn't show the microSD card even after formating. I need just the wtware 5.1.9 Image so I can rewrite it on our sdcards.
Roland
duri3
Post
by duri3 » Fri Nov 10, 2017 2:35 pm
Nevermind I used another laptop to write the image and now it's working fine! Thank you so much!
Best regards
Roland
Post
by aka » Fri Nov 10, 2017 5:06 pm
duri3 wrote: The configurator doesn't show the microSD card even after formating.
The configurator doesn't show the microSD card even with checkbox "Show all drives" ?
duri3
Post
by duri3 » Wed Dec 06, 2017 5:50 pm
Just for the record
No it didn't show on buildin SDreader on my HP Tower EliteDesk G1. But when I tried another HP Laptop it worked
