default error prompt on RDP disconnect
Fraal
Post by Fraal »
Hi team,
When disconnecting a session from a Windows 2016 Session Collection, upon reconnecting the session we are greeted with the below prompt,
wtware default error.PNG (3.15 KiB) Viewed 8225 times
Hitting OK simply removes the prompt, not sure whats causing this?
Cheers!
Re: default error prompt on RDP disconnect
Connect to the same server with the same username using mstsc.exe. If prompt appear, it's not related to wtware. Then ask google for solution for mstsc. Looks like some weird application in startup. Never saw this before.
Fraal
Post by Fraal »
Hi akatik,
Thanks for that, it seems it's a mstsc.exe thing and some application, does not occur on clean windows 10 VM's.
Cheers for the clarification!
