USB KEY on Raspberry
bcarme95
Post by bcarme95 »
I plugged a usb key into my raspberry Pi3 but it is not detected on my windows server 2012, how to see it please?
Re: USB KEY on Raspberry
There are no magic "see my usb key".
For USB disk: https://wtware.com/docs5/config.html#disk
disk=usb
For smart cards: https://wtware.com/docs5/smartcard.html
For general USB bus redirection:
viewforum.php?f=27
viewforum.php?f=25
bcarme95
Post by bcarme95 »
I put this command but I still do not see my usb key
bcarme95
Post by bcarme95 »
sorry but it does not work.
in which file to put disk = usb
config file, config.txt?
Thank you
config.wtc in configs folder.
It's better to edit this file in web interface. Open terminal IP in web browser.
bcarme95
Post by bcarme95 »
I just did it but I still do not see the usb key
bcarme95
Post by bcarme95 »
i give you the log, i just change IP serveur (xx.xxx.xx.xx), thanks
16-29-34-282| [ KERNEL] [ 291.732293] scsi 0:0:0:0: Direct-Access Kingston DataTraveler G3 1.00 PQ: 0 ANSI: 2
16-29-34-283| [ KERNEL] [ 291.734058] sd 0:0:0:0: [sda] 15636304 512-byte logical blocks: (8.01 GB/7.46 GiB)
16-29-34-284| [ KERNEL] [ 291.734476] sd 0:0:0:0: [sda] Write Protect is off
16-29-34-286| [ KERNEL] [ 291.734507] sd 0:0:0:0: [sda] Mode Sense: 03 00 00 00
16-29-34-287| [ KERNEL] [ 291.734901] sd 0:0:0:0: [sda] No Caching mode page found
16-29-34-288| [ KERNEL] [ 291.734921] sd 0:0:0:0: [sda] Assuming drive cache: write through
16-29-34-289| [ KERNEL] [ 291.738447] sda: sda1
16-29-34-290| [ KERNEL] [ 291.740888] sd 0:0:0:0: [sda] Attached SCSI removable disk
16-29-34-294| [ hotplug] [ 291.746126] Filesystem signature not found at /dev/sda.
16-29-34-296| [ hotplug] [ 291.746381] 00000000:33C08ED0BC007C8EC08ED8BE007CBF0006B90002FCF3A450681C06CBFBB90400 3.....|......|.........Ph......
16-29-34-296| [ hotplug] [ 291.746515] 00000020:BDBE07807E00007C0B0F850E0183C510E2F1CD1888560055C6461105C6461000 ....~..|...........V.U.F..F.
16-29-34-296| [ hotplug] [ 291.746637] 00000040:B441BBAA55CD135D720F81FB55AA7509F7C101007403FE46106660807E100074 .A..U.]r...U.u.....t..Ff`.~.t
16-29-34-298| [ hotplug] [ 291.746760] 00000060:2666680000000066FF760868000068007C680100681000B4428A56008BF4CD13 &fh....f.v.h..h.|h..h..B.V....
16-29-34-298| [ hotplug] [ 291.746883] 00000080:9F83C4109EEB14B80102BB007C8A56008A76018A4E028A6E03CD136661731CFE ..........|.V..v..N..n..fas.
16-29-34-300| [ hotplug] [ 291.747006] 000000a0:4E11750C807E00800F848A00B280EB845532E48A5600CD135DEB9E813EFE7D55 Nu..~..........U2..V..]...>.}U
16-29-34-300| [ hotplug] [ 291.747141] 000000c0:AA756EFF7600E88D007517FAB0D1E664E88300B0DFE660E87C00B0FFE664E875 .un.v....u....d......`.|....d.u
16-29-34-302| [ hotplug] [ 291.747262] 000000e0:00FBB800BBCD1A6623C0753B6681FB54435041753281F90201722C666807BB00 ......f#.u;f..TCPAu2....r,fh...
16-29-34-305| [ hotplug] [ 291.747381] 00000100:006668000200006668080000006653665366556668000000006668007C000066 .fh....fh....fSfSfUfh....fh.|..f
16-29-34-305| [ hotplug] [ 291.747503] 00000120:6168000007CD1A5A32F6EA007C0000CD18A0B707EB08A0B607EB03A0B50732E4 ah....Z2...|................2.
16-29-34-307| [ hotplug] [ 291.747623] 00000140:0500078BF0AC3C007409BB0700B40ECD10EBF2F4EBFD2BC9E464EB002402E0F8 ......<.t............+..d..$...
16-29-34-307| [ hotplug] [ 291.747745] 00000160:2402C3496E76616C696420706172746974696F6E207461626C65004572726F72 $..Invalid partition table.Error
16-29-34-309| [ hotplug] [ 291.747864] 00000180:206C6F6164696E67206F7065726174696E672073797374656D004D697373696E loading operating system.Missin
16-29-34-309| [ hotplug] [ 291.748000] 000001a0:67206F7065726174696E672073797374656D000000637B9A7F30FB9E00008020 g operating system...c{.0.....
16-29-34-311| [ hotplug] [ 291.748120] 000001c0:21000BFEFFCC000800000088EE00000000000000000000000000000000000000 !...............................
16-29-34-311| [ hotplug] [ 291.748254] 000001e0:00000000000000000000000000000000000000000000000000000000000055AA ..............................U.
16-29-34-311| [ hotplug] [ 291.749950] Success: USB1p1 mounted VFAT r/w.
16-29-34-313| [ KERNEL] [ 291.751374] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
16-29-34-313| [ rdpclient 774] [ 291.750398] Announce new disk named USB1 at /mnt/usb-rdp/1, r/w.
16-29-38-562| [wtc.exe] Terminal will restart now.
16-29-38-562| RSH: got command restart from 192.168.0.71.
16-29-38-563| Reboot.
16-29-38-564| [ gm] [ 296.015013] TSClient (sessionId 9, pid 774) gracefully end.
16-29-38-565| [ rdpclient 774] [ 296.015147] Send Disconnect Provider Ultimatum.
16-29-38-566| [ gm] [ 296.015819] Going to shutdown. Will not start sequent session.
16-29-38-573| [ pfac] [ 296.025593] Process pid 774 terminated, status 00000009.
16-29-48-590| [wtc.exe] Connection closed.
16-30-06-427| WTware 5.8.46/RPi supervisor.
16-30-06-427| [ KERNEL] [ 0.000000] Booting Linux on physical CPU 0x0
16-30-06-427| [ KERNEL] [ 0.000000] Linux version 4.14.92 (aka@c22) (gcc version 6.3.0 20170516 (Debian 6.3.0-18)) #3 SMP Fri Jan 11 18:27:02 EST 2019
16-30-06-427| [ KERNEL] [ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
16-30-06-427| [ KERNEL] [ 0.000000] CPU: div instructions available: patching division code
16-30-06-427| [ KERNEL] [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
16-30-06-427| [ KERNEL] [ 0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Plus Rev 1.3
16-30-06-427| [ KERNEL] [ 0.000000] Memory policy: Data cache writealloc
16-30-06-427| [ KERNEL] [ 0.000000] cma: Reserved 8 MiB at 0x3ac00000
16-30-06-427| [ KERNEL] [ 0.000000] On node 0 totalpages: 242688
16-30-06-427| [ KERNEL] [ 0.000000] free_area_init_node: node 0, pgdat 80a1edc0, node_mem_map ba48c000
16-30-06-427| [ KERNEL] [ 0.000000] Normal zone: 1896 pages used for memmap
16-30-06-427| [ KERNEL] [ 0.000000] Normal zone: 0 pages reserved
16-30-06-427| [ KERNEL] [ 0.000000] Normal zone: 242688 pages, LIFO batch:31
16-30-06-427| [ KERNEL] [ 0.000000] percpu: Embedded 14 pages/cpu @ba441000 s28236 r8192 d20916 u57344
16-30-06-427| [ KERNEL] [ 0.000000] pcpu-alloc: s28236 r8192 d20916 u57344 alloc=14*4096
16-30-06-427| [ KERNEL] [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
16-30-06-427| [ KERNEL] [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 240792
16-30-06-427| [ KERNEL] [ 0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbdepth=32 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 quiet wtboot=mmc
16-30-06-427| [ KERNEL] [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
16-30-06-427| [ KERNEL] [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
16-30-06-427| [ KERNEL] [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
16-30-06-427| [ KERNEL] [ 0.000000] Memory: 944100K/970752K available (4096K kernel code, 126K rwdata, 564K rodata, 4096K init, 350K bss, 18460K reserved, 8192K cma-reserved)
16-30-06-427| [ KERNEL] [ 0.000000] Virtual kernel memory layout:
16-30-06-427| [ KERNEL] [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
16-30-06-427| [ KERNEL] [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
16-30-06-427| [ KERNEL] [ 0.000000] vmalloc : 0xbb800000 - 0xff800000 (1088 MB)
16-30-06-427| [ KERNEL] [ 0.000000] lowmem : 0x80000000 - 0xbb400000 ( 948 MB)
16-30-06-427| [ KERNEL] [ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
16-30-06-427| [ KERNEL] [ 0.000000] .text : 0x80008000 - 0x80500000 (5088 kB)
16-30-06-427| [ KERNEL] [ 0.000000] .init : 0x80600000 - 0x80a00000 (4096 kB)
16-30-06-427| [ KERNEL] [ 0.000000] .data : 0x80a00000 - 0x80a1f9a8 ( 127 kB)
16-30-06-427| [ KERNEL] [ 0.000000] .bss : 0x80a21000 - 0x80a78ab0 ( 351 kB)
16-30-06-427| [ KERNEL] [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
16-30-06-427| [ KERNEL] [ 0.000000] Hierarchical RCU implementation.
16-30-06-427| [ KERNEL] [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
16-30-06-427| [ KERNEL] [ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
16-30-06-427| [ KERNEL] [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
16-30-06-427| [ KERNEL] [ 0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
16-30-06-427| [ KERNEL] [ 0.000017] Switching to timer-based delay loop, resolution 52ns
16-30-06-427| [ KERNEL] [ 0.000206] Console: colour dummy device 80x30
16-30-06-427| [ KERNEL] [ 0.000221] console [tty0] enabled
16-30-06-427| [ KERNEL] [ 0.000243] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
16-30-06-427| [ KERNEL] [ 0.000256] pid_max: default: 32768 minimum: 301
16-30-06-427| [ KERNEL] [ 0.000381] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
16-30-06-427| [ KERNEL] [ 0.000395] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
16-30-06-427| [ KERNEL] [ 0.000971] CPU: Testing write buffer coherency: ok
16-30-06-427| [ KERNEL] [ 0.001309] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
16-30-06-427| [ KERNEL] [ 0.001620] Setting up static identity map for 0x100000 - 0x10003c
16-30-06-427| [ KERNEL] [ 0.001721] Hierarchical SRCU implementation.
16-30-06-427| [ KERNEL] [ 0.002239] smp: Bringing up secondary CPUs ...
16-30-06-427| [ KERNEL] [ 0.002818] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
16-30-06-427| [ KERNEL] [ 0.003454] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
16-30-06-427| [ KERNEL] [ 0.004065] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
16-30-06-427| [ KERNEL] [ 0.004146] smp: Brought up 1 node, 4 CPUs
16-30-06-427| [ KERNEL] [ 0.004156] SMP: Total of 4 processors activated (153.60 BogoMIPS).
16-30-06-427| [ KERNEL] [ 0.004160] CPU: All CPU(s) started in HYP mode.
16-30-06-427| [ KERNEL] [ 0.004163] CPU: Virtualization extensions available.
16-30-06-427| [ KERNEL] [ 0.004771] devtmpfs: initialized
16-30-06-427| [ KERNEL] [ 0.013673] random: get_random_u32 called from 0x802a5cd8 with crng_init=0
16-30-06-427| [ KERNEL] [ 0.014048] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
16-30-06-427| [ KERNEL] [ 0.014369] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
16-30-06-427| [ KERNEL] [ 0.014384] futex hash table entries: 1024 (order: 4, 65536 bytes)
16-30-06-427| [ KERNEL] [ 0.014795] pinctrl core: initialized pinctrl subsystem
16-30-06-427| [ KERNEL] [ 0.015175] NET: Registered protocol family 16
16-30-06-427| [ KERNEL] [ 0.017203] DMA: preallocated 1024 KiB pool for atomic coherent allocations
16-30-06-427| [ KERNEL] [ 0.023399] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
16-30-06-427| [ KERNEL] [ 0.059587] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb813000, dmachans=0x1
16-30-06-427| [ KERNEL] [ 0.060949] usbcore: registered new interface driver usbfs
16-30-06-427| [ KERNEL] [ 0.060998] usbcore: registered new interface driver hub
16-30-06-427| [ KERNEL] [ 0.061060] usbcore: registered new device driver usb
16-30-06-427| [ KERNEL] [ 0.070135] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-01-09 20:04
16-30-06-427| [ KERNEL] [ 0.071209] clocksource: Switched to clocksource arch_sys_counter
16-30-06-427| [ KERNEL] [ 0.079347] NET: Registered protocol family 2
16-30-06-427| [ KERNEL] [ 0.079890] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
16-30-06-427| [ KERNEL] [ 0.079998] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
16-30-06-427| [ KERNEL] [ 0.080222] TCP: Hash tables configured (established 8192 bind 8192)
16-30-06-427| [ KERNEL] [ 0.080349] UDP hash table entries: 512 (order: 2, 16384 bytes)
16-30-06-427| [ KERNEL] [ 0.080392] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
16-30-06-427| [ KERNEL] [ 0.080586] NET: Registered protocol family 1
16-30-06-427| [ KERNEL] [ 2.188322] workingset: timestamp_bits=30 max_order=18 bucket_order=0
16-30-06-427| [ KERNEL] [ 2.237050] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
16-30-06-427| [ KERNEL] [ 2.237063] io scheduler noop registered
16-30-06-427| [ KERNEL] [ 2.237069] io scheduler deadline registered (default)
16-30-06-427| [ KERNEL] [ 2.239923] BCM2708FB: allocated DMA memory fad00000
16-30-06-427| [ KERNEL] [ 2.239975] BCM2708FB: allocated DMA channel 0 @ bb813000
16-30-06-427| [ KERNEL] [ 2.293962] Console: switching to colour frame buffer device 240x67
16-30-06-427| [ KERNEL] [ 2.326492] bcm2835-rng 3f104000.rng: hwrng registered
16-30-06-427| [ KERNEL] [ 2.326832] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
16-30-06-427| [ KERNEL] [ 2.328091] vc-sm: Videocore shared memory driver
16-30-06-427| [ KERNEL] [ 2.328787] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
16-30-06-427| [ KERNEL] [ 2.330283] zram: Added device: zram0
16-30-06-427| [ KERNEL] [ 2.330816] libphy: Fixed MDIO Bus: probed
16-30-06-427| [ KERNEL] [ 2.330910] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
16-30-06-427| [ KERNEL] [ 2.359067] dwc_otg 3f980000.usb: base=0xf0980000
16-30-06-427| [ KERNEL] [ 2.559273] Core Release: 2.80a
16-30-06-427| [ KERNEL] [ 2.559282] Setting default values for core params
16-30-06-427| [ KERNEL] [ 2.559309] Finished setting default values for core params
16-30-06-427| [ KERNEL] [ 2.759576] Using Buffer DMA mode
16-30-06-427| [ KERNEL] [ 2.759584] Periodic Transfer Interrupt Enhancement - disabled
16-30-06-427| [ KERNEL] [ 2.759588] Multiprocessor Interrupt Enhancement - disabled
16-30-06-427| [ KERNEL] [ 2.759595] OTG VER PARAM: 0, OTG VER FLAG: 0
16-30-06-427| [ KERNEL] [ 2.759607] Dedicated Tx FIFOs mode
16-30-06-427| [ KERNEL] [ 2.760072] WARN::dwc_otg_hcd_init:1046: FIQ DMA bounce buffers: virt = 0xbad14000 dma = 0xfad14000 len=9024
16-30-06-427| [ KERNEL] [ 2.760097] FIQ FSM acceleration enabled for :
16-30-06-427| [ KERNEL] [ 2.760097] Non-periodic Split Transactions
16-30-06-427| [ KERNEL] [ 2.760097] Periodic Split Transactions
16-30-06-427| [ KERNEL] [ 2.760097] High-Speed Isochronous Endpoints
16-30-06-427| [ KERNEL] [ 2.760097] Interrupt/Control Split Transaction hack enabled
16-30-06-427| [ KERNEL] [ 2.760104] dwc_otg: Microframe scheduler enabled
16-30-06-427| [ KERNEL] [ 2.760148] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x8036e368
16-30-06-427| [ KERNEL] [ 2.760157] WARN::hcd_init_fiq:460: FIQ ASM at 0x8036e6c0 length 36
16-30-06-427| [ KERNEL] [ 2.760168] WARN::hcd_init_fiq:486: MPHI regs_base at 0xf0006000
16-30-06-427| [ KERNEL] [ 2.760217] dwc_otg 3f980000.usb: DWC OTG Controller
16-30-06-427| [ KERNEL] [ 2.760247] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
16-30-06-427| [ KERNEL] [ 2.760278] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
16-30-06-427| [ KERNEL] [ 2.760325] Init: Port Power? op_state=1
16-30-06-427| [ KERNEL] [ 2.760329] Init: Power Port (0)
16-30-06-427| [ KERNEL] [ 2.760502] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
16-30-06-427| [ KERNEL] [ 2.760512] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
16-30-06-427| [ KERNEL] [ 2.760520] usb usb1: Product: DWC OTG Controller
16-30-06-427| [ KERNEL] [ 2.760528] usb usb1: Manufacturer: Linux 4.14.92 dwc_otg_hcd
16-30-06-427| [ KERNEL] [ 2.760535] usb usb1: SerialNumber: 3f980000.usb
16-30-06-427| [ KERNEL] [ 2.761287] hub 1-0:1.0: USB hub found
16-30-06-427| [ KERNEL] [ 2.761335] hub 1-0:1.0: 1 port detected
16-30-06-427| [ KERNEL] [ 2.762185] dwc_otg: FIQ enabled
16-30-06-427| [ KERNEL] [ 2.762193] dwc_otg: NAK holdoff enabled
16-30-06-427| [ KERNEL] [ 2.762197] dwc_otg: FIQ split-transaction FSM enabled
16-30-06-427| [ KERNEL] [ 2.762269] Module dwc_common_port init
16-30-06-427| [ KERNEL] [ 2.764861] usbcore: registered new interface driver usbtouchscreen
16-30-06-427| [ KERNEL] [ 2.765976] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
16-30-06-427| [ KERNEL] [ 2.766510] bcm2835-cpufreq: min=600000 max=1400000
16-30-06-427| [ KERNEL] [ 2.767191] sdhci: Secure Digital Host Controller Interface driver
16-30-06-427| [ KERNEL] [ 2.767201] sdhci: Copyright(c) Pierre Ossman
16-30-06-427| [ KERNEL] [ 2.767714] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
16-30-06-427| [ KERNEL] [ 2.768266] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
16-30-06-427| [ KERNEL] [ 2.768419] sdhci-pltfm: SDHCI platform and OF driver helper
16-30-06-427| [ KERNEL] [ 2.768526] hidraw: raw HID events driver (C) Jiri Kosina
16-30-06-427| [ KERNEL] [ 2.769164] usbcore: registered new interface driver usbhid
16-30-06-427| [ KERNEL] [ 2.769170] usbhid: USB HID core driver
16-30-06-427| [ KERNEL] [ 2.770641] vchiq: vchiq_init_state: slot_zero = bad80000, is_master = 0
16-30-06-427| [ KERNEL] [ 2.781349] [vc_sm_connected_init]: start
16-30-06-427| [ KERNEL] [ 2.789065] [vc_sm_connected_init]: end - returning 0
16-30-06-427| [ KERNEL] [ 2.789526] NET: Registered protocol family 17
16-30-06-427| [ KERNEL] [ 2.789649] Registering SWP/SWPB emulation handler
16-30-06-427| [ KERNEL] [ 2.792969] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
16-30-06-427| [ KERNEL] [ 2.792981] mmc-bcm2835 3f300000.mmc: DMA channel allocated
16-30-06-427| [ KERNEL] [ 2.862239] sdhost: log_buf @ bad13000 (fad13000)
16-30-06-427| [ KERNEL] [ 2.897439] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
16-30-06-427| [ KERNEL] [ 2.898984] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
16-30-06-427| [ KERNEL] [ 2.900527] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
16-30-06-427| [ KERNEL] [ 2.903281] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
16-30-06-427| [ KERNEL] [ 2.941226] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
16-30-06-427| [ KERNEL] [ 2.941352] of_cfs_init
16-30-06-427| [ KERNEL] [ 2.941488] of_cfs_init: OK
16-30-06-427| [ KERNEL] [ 2.978731] Freeing unused kernel memory: 4096K
16-30-06-427| [ KERNEL] [ 2.991680] Indeed it is in host mode hprt0 = 00021501
16-30-06-427| [ KERNEL] [ 3.057695] random: fast init done
16-30-06-427| [ KERNEL] [ 3.065643] mmc1: new high speed SDIO card at address 0001
16-30-06-427| [ KERNEL] [ 3.089067] mmc0: host does not support reading read-only switch, assuming write-enable
16-30-06-427| [ KERNEL] [ 3.091676] mmc0: new high speed SDHC card at address 5048
16-30-06-427| [ KERNEL] [ 3.091953] mmcblk0: mmc0:5048 SD16G 14.5 GiB
16-30-06-427| [ KERNEL] [ 3.093443] mmcblk0: p1
16-30-06-427| [ hotplug] [ 3.095084] Block device 179:0. No action.
16-30-06-427| [ hotplug] [ 3.096125] Block device 179:1. No action.
16-30-06-427| [ KERNEL] [ 3.221243] usb 1-1: new high-speed USB device number 2 using dwc_otg
16-30-06-427| [ KERNEL] [ 3.221379] Indeed it is in host mode hprt0 = 00001101
16-30-06-427| [ hotplug] [ 3.238339] Block device 254:0. No action.
16-30-06-427| [ pfac] [ 3.377133] Run /sbin/initrd.
16-30-06-427| [ pfac] [ 3.377245] Ok, PID 609.
16-30-06-427| [ initrd] [ 3.381938] WTware 5.8.46/RPi shell.
16-30-06-427| [ initrd] [ 3.382362] Load font 'ter-c32b.psf', console 120x33.
16-30-06-427| [ initrd] [ 3.419819] MMC boot.
16-30-06-427| [ initrd] [ 3.424622] Success: media /dev/mmcblk0p1 mounted to /bootmedia.
16-30-06-427| /--- FILE "/bootmedia/config.txt" -----------------------
16-30-06-427| | # For more options and information see:
16-30-06-427| | #
16-30-06-427| | # https://www.raspberrypi.org/documentati ... /README.md
16-30-06-427| | #
16-30-06-427| | # Some settings may impact device functionality. See link above for details.
16-30-06-427| | # Uncomment if you get no picture on HDMI for a default "safe" mode.
16-30-06-427| | #hdmi_safe=1
16-30-06-427| | # Uncomment this if your display has a black border of unused pixels visible
16-30-06-427| | # and your display can output without overscan.
16-30-06-427| | disable_overscan=1
16-30-06-427| | # Uncomment if hdmi display is not detected and composite is being output.
16-30-06-427| | #hdmi_force_hotplug=1
16-30-06-427| | # Uncomment to force a specific HDMI mode (this will force VGA).
16-30-06-427| | #hdmi_group=1
16-30-06-427| | #hdmi_mode=1
16-30-06-427| | # Force the monitor to HDMI mode so that sound will be sent over HDMI cable.
16-30-06-427| | #hdmi_drive=2
16-30-06-427| | # Uncomment to increase signal to HDMI, if you have interference, blanking, or
16-30-06-427| | # no display.
16-30-06-427| | #config_hdmi_boost=4
16-30-06-427| | # Uncomment to overclock the arm. 700 MHz is the default.
16-30-06-427| | #arm_freq=800
16-30-06-427| | disable_splash=1
16-30-06-427| | #hdmi_group=2
16-30-06-427| | # 800x600: hdmi_mode=9
16-30-06-427| | # 1024x768: hdmi_mode=16
16-30-06-427| | # 1280x1024: hdmi_mode=35
16-30-06-427| | # 1360x768: hdmi_mode=39
16-30-06-427| | # 1400x1050: hdmi_mode=42
16-30-06-427| | # 1440x900: hdmi_mode=47
16-30-06-427| | # 1600x1200: hdmi_mode=51
16-30-06-427| | # 1680x1050: hdmi_mode=58
16-30-06-427| | # 1366x768: hdmi_mode=81
16-30-06-427| | # 1920x1080: hdmi_mode=82
16-30-06-427| | # 1920x1200: hdmi_mode=69
16-30-06-427| | framebuffer_depth=32
16-30-06-427| | # Uncomment for 16-bit color. It is up to two
16-30-06-427| | # times faster than default 32-bit.
16-30-06-427| | #framebuffer_depth=16
16-30-06-427| | # Enable onboard audio (HDMI or jack).
16-30-06-427| | dtparam=audio=on
16-30-06-427| | # Removes the warning overlay.
16-30-06-427| | #avoid_warnings=1
16-30-06-427| | # Additionally allows turbo when low-voltage is present.
16-30-06-427| | #avoid_warnings=2
16-30-06-427| | hdmi_group=2
16-30-06-427| | hdmi_mode=82
16-30-06-427| | disk=usb
16-30-06-427| \----------------------------------------------------
16-30-06-427| [ KERNEL] [ 3.471497] usb 1-1: New USB device found, idVendor=0424, idProduct=2514
16-30-06-427| [ KERNEL] [ 3.471509] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
16-30-06-427| [ KERNEL] [ 3.472124] hub 1-1:1.0: USB hub found
16-30-06-427| [ KERNEL] [ 3.472239] hub 1-1:1.0: 4 ports detected
16-30-06-427| [ KERNEL] [ 3.791246] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
16-30-06-427| [ KERNEL] [ 3.921453] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514
16-30-06-427| [ KERNEL] [ 3.921466] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
16-30-06-427| [ KERNEL] [ 3.922091] hub 1-1.1:1.0: USB hub found
16-30-06-427| [ KERNEL] [ 3.922200] hub 1-1.1:1.0: 3 ports detected
16-30-06-427| [ KERNEL] [ 4.021244] usb 1-1.2: new low-speed USB device number 4 using dwc_otg
16-30-06-427| [ KERNEL] [ 4.156118] usb 1-1.2: New USB device found, idVendor=093a, idProduct=2510
16-30-06-427| [ KERNEL] [ 4.156129] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
16-30-06-427| [ KERNEL] [ 4.156137] usb 1-1.2: Product: USB Optical Mouse
16-30-06-427| [ KERNEL] [ 4.156145] usb 1-1.2: Manufacturer: PixArt
16-30-06-427| [ KERNEL] [ 4.161024] input: PixArt USB Optical Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:093A:2510.0001/input/input0
16-30-06-427| [ KERNEL] [ 4.161501] hid-generic 0003:093A:2510.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-3f980000.usb-1.2/input0
16-30-06-427| [ KERNEL] [ 4.271236] usb 1-1.1.2: new high-speed USB device number 5 using dwc_otg
16-30-06-427| [ KERNEL] [ 4.403368] usb 1-1.1.2: New USB device found, idVendor=0951, idProduct=1643
16-30-06-427| [ KERNEL] [ 4.403379] usb 1-1.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
16-30-06-427| [ KERNEL] [ 4.403387] usb 1-1.1.2: Product: DataTraveler G3
16-30-06-427| [ KERNEL] [ 4.403395] usb 1-1.1.2: Manufacturer: Kingston
16-30-06-427| [ KERNEL] [ 4.403402] usb 1-1.1.2: SerialNumber: 001CC0EC345CF08075C41321
16-30-06-427| [ KERNEL] [ 4.501244] usb 1-1.3: new low-speed USB device number 6 using dwc_otg
16-30-06-427| [ KERNEL] [ 4.658490] usb 1-1.3: New USB device found, idVendor=045e, idProduct=0750
16-30-06-427| [ KERNEL] [ 4.658501] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
16-30-06-427| [ KERNEL] [ 4.658509] usb 1-1.3: Product: Wired Keyboard 600
16-30-06-427| [ KERNEL] [ 4.658517] usb 1-1.3: Manufacturer: Microsoft
16-30-06-427| [ KERNEL] [ 4.674244] input: Microsoft Wired Keyboard 600 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:045E:0750.0002/input/input1
16-30-06-427| [ KERNEL] [ 4.731252] usb 1-1.1.1: new high-speed USB device number 7 using dwc_otg
16-30-06-427| [ KERNEL] [ 4.742082] microsoft 0003:045E:0750.0002: input,hidraw1: USB HID v1.11 Keyboard [Microsoft Wired Keyboard 600] on usb-3f980000.usb-1.3/input0
16-30-06-427| [ KERNEL] [ 4.760416] input: Microsoft Wired Keyboard 600 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:045E:0750.0003/input/input2
16-30-06-427| [ KERNEL] [ 4.821615] microsoft 0003:045E:0750.0003: input,hidraw2: USB HID v1.11 Device [Microsoft Wired Keyboard 600] on usb-3f980000.usb-1.3/input1
16-30-06-427| [ KERNEL] [ 4.861578] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800
16-30-06-427| [ KERNEL] [ 4.861594] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
16-30-06-427| [ initrd] [ 4.882723] Cache package files: auto.
16-30-06-427| [ initrd] [ 4.882844] WTpassword present: d3d116ecb8c46baeaa7feb1e688eae8c.
16-30-06-427| [ initrd] [ 4.885692] Cache package files.
16-30-06-427| [ initrd] [ 4.948390] USB: 0951:1643 Kingston Technology DataTraveler G3.
16-30-06-427| [ initrd] [ 4.948473] USB: 045e:0750 Microsoft Corp. Wired Keyboard 600.
16-30-06-427| [ initrd] [ 4.948505] USB: 0424:2514 Standard Microsystems Corp. USB 2.0 Hub.
16-30-06-427| [ initrd] [ 4.948535] USB: 0424:7800 Standard Microsystems Corp..
16-30-06-427| [ initrd] [ 4.948565] USB: 093a:2510 Pixart Imaging, Inc. Optical Mouse.
16-30-06-427| /--- FILE "/bootmedia/configs/initrd.wtc" -----------------------
16-30-06-427| | [BOM]
16-30-06-427| | clientIP=*
16-30-06-427| | config=local
16-30-06-427| | setupPassword=d3d116ecb8c46baeaa7feb1e688eae8c
16-30-06-427| | netmedia=ethernet
16-30-06-427| [ initrd] [ 6.914721] Load ethernet drivers.
16-30-06-427| [ initrd] [ 6.914796] modprobe lan78xx.
16-30-06-427| [ KERNEL] [ 7.054027] libphy: lan78xx-mdiobus: probed
16-30-06-427| [ KERNEL] [ 7.058269] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): int urb period 64
16-30-06-427| [ initrd] [ 7.203360] modprobe smsc95xx.
16-30-06-427| [ KERNEL] [ 7.203510] usbcore: registered new interface driver lan78xx
16-30-06-427| [ KERNEL] [ 7.214334] usbcore: registered new interface driver smsc95xx
16-30-06-427| [ initrd] [ 10.320744] WTpassword present: d3d116ecb8c46baeaa7feb1e688eae8c.
16-30-06-427| [ KERNEL] [ 11.264758] random: crng init done
16-30-06-427| [ initrd] [ 11.580160] dhcp: 576 bytes from 192.168.0.254.
16-30-06-427| [ initrd] [ 11.580265] 00000000:0000022C0000000000110000C0A800FEC0A8004400430044022C000002010600 ...,..............D.C.D.,......
16-30-06-427| [ initrd] [ 11.580338] 00000020:67458B6B0000000000000000C0A800440000000000000000B827EB9FC4040000 gE.k...........D.........'......
16-30-06-427| [ initrd] [ 11.580410] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
16-30-06-427| [ initrd] [ 11.580481] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
16-30-06-427| [ initrd] [ 11.580551] 00000080:0000000000000000000000000000000000000000000000000000000000000000 ................................
16-30-06-427| [ initrd] [ 11.580621] 000000a0:0000000000000000000000000000000000000000000000000000000000000000 ................................
16-30-06-427| [ initrd] [ 11.580690] 000000c0:0000000000000000000000000000000000000000000000000000000000000000 ................................
16-30-06-427| [ initrd] [ 11.580758] 000000e0:0000000000000000000000000000000000000000000000000000000000000000 ................................
16-30-06-427| [ initrd] [ 11.580827] 00000100:0000000000000000638253633501023604C0A800FE33040000A8C00104FFFFFF ........c.Sc5..6.....3..........
16-30-06-427| [ initrd] [ 11.580895] 00000120:000304C0A800FE0604C0A800FEFF000000000000000000000000000000000000 ................................
16-30-06-427| [ initrd] [ 11.580964] 00000140:0000000000000000000000000000000000000000000000000000000000000000 ................................
16-30-06-427| [ initrd] [ 11.581032] 00000160:0000000000000000000000000000000000000000000000000000000000000000 ................................
16-30-06-427| [ initrd] [ 11.581101] 00000180:0000000000000000000000000000000000000000000000000000000000000000 ................................
16-30-06-427| [ initrd] [ 11.581169] 000001a0:0000000000000000000000000000000000000000000000000000000000000000 ................................
16-30-06-427| [ initrd] [ 11.581238] 000001c0:0000000000000000000000000000000000000000000000000000000000000000 ................................
16-30-06-427| [ initrd] [ 11.581309] 000001e0:0000000000000000000000000000000000000000000000000000000000000000 ................................
16-30-06-427| [ initrd] [ 11.581378] 00000200:0000000000000000000000000000000000000000000000000000000000000000 ................................
16-30-06-427| [ initrd] [ 11.581447] 00000220:0000000000000000000000000000000000000000000000000000000000000000 ................................
16-30-06-427| [ initrd] [ 14.701117] dhcp: 576 bytes from 192.168.0.254.
16-30-06-427| [ initrd] [ 14.701229] 00000000:0000022C0000000000110000C0A800FEC0A8004400430044022C000002010600 ...,..............D.C.D.,......
16-30-06-427| [ initrd] [ 14.701303] 00000020:67458B6B0000000000000000C0A800440000000000000000B827EB9FC4040000 gE.k...........D.........'......
16-30-06-427| [ initrd] [ 14.701373] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
16-30-06-427| [ initrd] [ 14.701442] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
16-30-06-427| [ initrd] [ 14.701512] 00000080:0000000000000000000000000000000000000000000000000000000000000000 ................................
16-30-06-427| [ initrd] [ 14.701581] 000000a0:0000000000000000000000000000000000000000000000000000000000000000 ................................
16-30-06-427| [ initrd] [ 14.701649] 000000c0:0000000000000000000000000000000000000000000000000000000000000000 ................................
16-30-06-427| [ initrd] [ 14.701718] 000000e0:0000000000000000000000000000000000000000000000000000000000000000 ................................
16-30-06-427| [ initrd] [ 14.701786] 00000100:0000000000000000638253633501053604C0A800FE33040000A8C00104FFFFFF ........c.Sc5..6.....3..........
16-30-06-427| [ initrd] [ 14.701855] 00000120:000304C0A800FE0604C0A800FEFF000000000000000000000000000000000000 ................................
16-30-06-427| [ initrd] [ 14.701923] 00000140:0000000000000000000000000000000000000000000000000000000000000000 ................................
16-30-06-427| [ initrd] [ 14.702007] 00000160:0000000000000000000000000000000000000000000000000000000000000000 ................................
16-30-06-427| [ initrd] [ 14.702076] 00000180:0000000000000000000000000000000000000000000000000000000000000000 ................................
16-30-06-427| [ initrd] [ 14.702145] 000001a0:0000000000000000000000000000000000000000000000000000000000000000 ................................
16-30-06-427| [ initrd] [ 14.702214] 000001c0:0000000000000000000000000000000000000000000000000000000000000000 ................................
16-30-06-427| [ initrd] [ 14.702282] 000001e0:0000000000000000000000000000000000000000000000000000000000000000 ................................
16-30-06-427| [ initrd] [ 14.702350] 00000200:0000000000000000000000000000000000000000000000000000000000000000 ................................
16-30-06-427| [ initrd] [ 14.702419] 00000220:0000000000000000000000000000000000000000000000000000000000000000 ................................
16-30-06-427| [ initrd] [ 14.740097] [DHCP] DHCP server address 192.168.0.254.
16-30-06-427| [ initrd] [ 14.740171] [DHCP] IP 192.168.0.68 mask 255.255.255.0.
16-30-06-427| [ initrd] [ 14.740241] [DHCP] Default gateway 192.168.0.254.
16-30-06-427| [ initrd] [ 14.740308] [DHCP] DNS 192.168.0.254.
16-30-06-427| [ initrd] [ 14.740375] [DHCP] TFTP = DHCP 192.168.0.254.
16-30-06-427| [ initrd] [ 14.740442] [DHCP] TFTP 192.168.0.254.
16-30-06-427| [ initrd] [ 14.740508] [DHCP] No boot file from DHCP.
16-30-06-427| [ initrd] [ 14.740573] [DHCP] TFTP binary "", configs prefix "", using "/" slash.
16-30-06-427| WTC listener is active.
16-30-06-427| WTC broadcast listener is active.
16-30-06-427| Send broadcast WTCU discover.
16-30-06-427| [ pfac] [ 14.743033] Run /sbin/httpd.
16-30-06-427| [ initrd] [ 14.743106] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
16-30-06-427| [ pfac] [ 14.743238] Ok, PID 679.
16-30-06-427| [ initrd] [ 14.743289] Copy /bootmedia/configs/config.wtc to /tmp/config.wtc.
16-30-06-427| [ initrd] [ 14.743428] Common local disk config:
16-30-06-427| /--- FILE "/tmp/config.wtc" -----------------------
16-30-06-427| | server=xx.xxx.xxx.xx
16-30-06-427| | user=frank
16-30-06-427| | keyboard=fr
16-30-06-427| | connection
16-30-06-427| /--- FILE "/etc/config.compiled" -----------------------
16-30-06-427| [ initrd] [ 14.744946] Hostname: "wtwB827EB9FC404".
16-30-06-427| [ httpd] [ 14.747221] HTTP Server, WTware 5.8.46/RPi
16-30-06-427| [ initrd] [ 15.000397] [NTP] 42 DHCP option is not set.
16-30-06-427| Everyone can control terminal by RSH.
16-30-06-427| RSH: listener is active.
16-30-06-427| [ httpd] [ 15.005345] Reread settings.
16-30-06-427| [ httpd] [ 15.005501] Everyone can control terminal by HTTP.
16-30-06-427| [ initrd] [ 15.062378] [FILE CACHE] Take 'packages/pi2-f' from cache.
16-30-06-427| [ gm] [ 15.068409] WTware 5.8.46/RPi session manager.
16-30-06-427| [ gm] [ 15.069475] Add keyboard event2: Microsoft Wired Keyboard 600.
16-30-06-427| [ gm] [ 15.069559] Add keyboard event1: Microsoft Wired Keyboard 600.
16-30-06-427| [ gm] [ 15.069636] EV_REL flag found. Add mouse event0: PixArt USB Optical Mouse.
16-30-06-427| [ gm] [ 15.069765] Display mode: 1920x1080, 32 bit, landscape, 0 Hz, modeline "", DDC enabled, connector 0.
16-30-06-427| [ gm] [ 15.909413] Framebuffer device found.
16-30-06-427| [ gm] [ 15.909500] LINELENBYTES 7680
16-30-06-427| [ gm] [ 15.909533] VLEN 8294400
16-30-06-427| [ gm] [ 15.910339] Use /lib/ui32.so.
16-30-06-427| [ gm] [ 15.939441] Load ISO 9660 and UDF CDROM filesystem drivers.
16-30-06-427| [ gm] [ 15.939510] modprobe udf.
16-30-06-427| [ gm] [ 15.944402] modprobe isofs.
16-30-06-427| [ gm] [ 15.949366] Load usb storage driver.
16-30-06-427| [ gm] [ 15.949471] modprobe scsi_mod.
16-30-06-427| [ gm] [ 15.955641] modprobe usb-storage.
16-30-06-427| [ KERNEL] [ 15.956050] SCSI subsystem initialized
16-30-06-427| [ gm] [ 15.962780] modprobe sd_mod.
16-30-06-427| [ KERNEL] [ 15.962728] usb-storage 1-1.1.2:1.0: USB Mass Storage device detected
16-30-06-427| [ KERNEL] [ 15.962880] scsi host0: usb-storage 1-1.1.2:1.0
16-30-06-427| [ KERNEL] [ 15.963164] usbcore: registered new interface driver usb-storage
16-30-06-427| [ gm] [ 15.968535] Load EXFAT filesystem driver.
16-30-06-427| [ gm] [ 15.968650] modprobe fuse.
16-30-06-427| [ gm] [ 15.974317] modprobe exfat.
16-30-06-427| [ KERNEL] [ 15.974550] fuse init (API version 7.26)
16-30-06-427| [ KERNEL] [ 15.980295] exFAT: Version 1.2.9
16-30-06-427| [ gm] [ 15.986759] Run '/sbin/resolver 0x973ba0 dns [xx.xxx.xxx.xx]', log '', env '', pid ''.
16-30-06-427| [ gm] [ 15.986858] Nobody can control terminal by VNC.
16-30-06-427| [ pfac] [ 15.987330] Run /sbin/resolver 0x973ba0 dns [xx.xxx.xxx.xx].
16-30-06-427| [ pfac] [ 15.987392] Ok, PID 721.
16-30-06-427| [ pfac] [ 15.990843] Process pid 721 terminated, status 00000000.
16-30-06-427| [ gm] [ 15.995509] xx.xxx.xxx.xx => xx.xxx.xxx.xx.
16-30-06-427| [ gm] [ 16.000716] Free ram before fork terminal client /sbin/rdpclient (session 1): 923860 Kb.
16-30-06-427| [ gm] [ 16.000813] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
16-30-06-427| [ pfac] [ 16.001087] Run /sbin/rdpclient 1.
16-30-06-427| [ pfac] [ 16.001134] Ok, PID 722.
16-30-06-427| [ rdpclient 722] [ 16.024788] RDP Terminal Client, WTware 5.8.46/RPi, pipe 1, pid 722.
16-30-06-427| [ rdpclient 722] [ 16.025160] Use /lib/ui32.so.
16-30-06-427| [ rdpclient 722] [ 16.025893] Make RDP session with xx.xxx.xxx.xx, port 3389.
16-30-06-427| [ rdpclient 722] [ 16.025998] Username: "frank".
16-30-06-427| [ rdpclient 722] [ 16.026037] No password.
16-30-06-427| [ rdpclient 722] [ 16.026074] No PIN.
16-30-06-427| [ rdpclient 722] [ 16.026130] No domain.
16-30-06-427| [ rdpclient 722] [ 16.026190] No shell.
16-30-06-427| [ rdpclient 722] [ 16.026228] No directory.
16-30-06-427| [ rdpclient 722] [ 16.026262] Window: 1856x1080@24.
16-30-06-427| [ rdpclient 722] [ 16.026297] PFlags 0x0000002F.
16-30-06-427| [ rdpclient 722] [ 16.026331] Keyboard 0000040C:00000000.
16-30-06-427| [ rdpclient 722] [ 16.026369] My hostname "wtwB827EB9FC404".
16-30-06-427| [ rdpclient 722] [ 16.026404] TCP: connecting to xx.xxx.xxx.xx:3389.
16-30-06-427| [ rdpclient 722] [ 16.051340] TCP: connection with xx.xxx.xxx.xx:3389 established.
16-30-06-427| [ rdpclient 722] [ 16.051496] Turn keepalive on.
16-30-06-427| [ rdpclient 722] [ 16.052298] Free ram after buffers allocation: 922688 KB.
16-30-06-427| [ rdpclient 722] [ 16.081041] Server supports GFX Pipeline.
16-30-06-427| [ rdpclient 722] [ 16.112749] Process RDP server certificate.
16-30-06-427| [ rdpclient 722] [ 16.112840] RDP4 encryption.
16-30-06-427| [ rdpclient 722] [ 16.318988] Enable font smoothing and Desktop Composition.
16-30-06-427| [ rdpclient 722] [ 16.459785] GFX codec.
16-30-06-427| [ rdpclient 722] [ 16.884887] Run 4 tile threads.
16-30-06-427| [ KERNEL] [ 17.031926] scsi 0:0:0:0: Direct-Access Kingston DataTraveler G3 1.00 PQ: 0 ANSI: 2
16-30-06-427| [ KERNEL] [ 17.033658] sd 0:0:0:0: [sda] 15636304 512-byte logical blocks: (8.01 GB/7.46 GiB)
16-30-06-427| [ KERNEL] [ 17.036638] sd 0:0:0:0: [sda] Write Protect is off
16-30-06-427| [ KERNEL] [ 17.036658] sd 0:0:0:0: [sda] Mode Sense: 03 00 00 00
16-30-06-427| [ KERNEL] [ 17.037843] sd 0:0:0:0: [sda] No Caching mode page found
16-30-06-427| [ KERNEL] [ 17.037871] sd 0:0:0:0: [sda] Assuming drive cache: write through
16-30-06-427| [ KERNEL] [ 17.041482] sda: sda1
16-30-06-427| [ KERNEL] [ 17.043591] sd 0:0:0:0: [sda] Attached SCSI removable disk
16-30-06-427| [ hotplug] [ 17.047568] Filesystem signature not found at /dev/sda.
16-30-06-427| [ hotplug] [ 17.047752] 00000000:33C08ED0BC007C8EC08ED8BE007CBF0006B90002FCF3A450681C06CBFBB90400 3.....|......|.........Ph......
16-30-06-427| [ hotplug] [ 17.047900] 00000020:BDBE07807E00007C0B0F850E0183C510E2F1CD1888560055C6461105C6461000 ....~..|...........V.U.F..F.
16-30-06-427| [ hotplug] [ 17.048043] 00000040:B441BBAA55CD135D720F81FB55AA7509F7C101007403FE46106660807E100074 .A..U.]r...U.u.....t..Ff`.~.t
16-30-06-427| [ hotplug] [ 17.048184] 00000060:2666680000000066FF760868000068007C680100681000B4428A56008BF4CD13 &fh....f.v.h..h.|h..h..B.V....
16-30-06-427| [ hotplug] [ 17.048326] 00000080:9F83C4109EEB14B80102BB007C8A56008A76018A4E028A6E03CD136661731CFE ..........|.V..v..N..n..fas.
16-30-06-427| [ hotplug] [ 17.048468] 000000a0:4E11750C807E00800F848A00B280EB845532E48A5600CD135DEB9E813EFE7D55 Nu..~..........U2..V..]...>.}U
16-30-06-427| [ hotplug] [ 17.048609] 000000c0:AA756EFF7600E88D007517FAB0D1E664E88300B0DFE660E87C00B0FFE664E875 .un.v....u....d......`.|....d.u
16-30-06-427| [ hotplug] [ 17.048765] 000000e0:00FBB800BBCD1A6623C0753B6681FB54435041753281F90201722C666807BB00 ......f#.u;f..TCPAu2....r,fh...
16-30-06-427| [ hotplug] [ 17.048906] 00000100:006668000200006668080000006653665366556668000000006668007C000066 .fh....fh....fSfSfUfh....fh.|..f
16-30-06-427| [ hotplug] [ 17.049047] 00000120:6168000007CD1A5A32F6EA007C0000CD18A0B707EB08A0B607EB03A0B50732E4 ah....Z2...|................2.
16-30-06-427| [ hotplug] [ 17.049187] 00000140:0500078BF0AC3C007409BB0700B40ECD10EBF2F4EBFD2BC9E464EB002402E0F8 ......<.t............+..d..$...
16-30-06-427| [ hotplug] [ 17.049328] 00000160:2402C3496E76616C696420706172746974696F6E207461626C65004572726F72 $..Invalid partition table.Error
16-30-06-427| [ hotplug] [ 17.049469] 00000180:206C6F6164696E67206F7065726174696E672073797374656D004D697373696E loading operating system.Missin
16-30-06-427| [ hotplug] [ 17.049609] 000001a0:67206F7065726174696E672073797374656D000000637B9A7F30FB9E00008020 g operating system...c{.0.....
16-30-06-427| [ hotplug] [ 17.049748] 000001c0:21000BFEFFCC000800000088EE00000000000000000000000000000000000000 !...............................
16-30-06-427| [ hotplug] [ 17.049888] 000001e0:00000000000000000000000000000000000000000000000000000000000055AA ..............................U.
16-30-06-427| [ hotplug] [ 17.051070] Success: USB1p1 mounted VFAT r/w.
16-30-06-427| [ KERNEL] [ 17.052126] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
16-30-06-427| [ rdpclient 722] [ 17.051566] Announce new disk named USB1 at /mnt/usb-rdp/1, r/w.
16-30-06-429| Connection from wtc.exe at 192.168.0.71.
bcarme95 wrote: Mon Apr 01, 2019 5:28 pm 16-30-06-427| [ rdpclient 722] [ 17.051566] Announce new disk named USB1 at /mnt/usb-rdp/1, r/w.
It says it redirected disk to server.
On terminal, run File Explorer. Open:
\\tsclient
What will you see here?
bcarme95
Post by bcarme95 »
I do not have access to \\ tsclient
1. Remove space between \\ and tsclient
2. Show me screen photo where it writes that you have no access.
3. On Windows machine, run mstsc.exe. Connect to the same RDP server. Login with the same user. Can you redirect USB KEY from windows machine? Do you have access to \\tsclient in mstsc.exe session?
bcarme95
Post by bcarme95 »
1. Yes i don't use space \\tsclient
2.Image
3. Yes i have access, i can't see usb key and i have access to \\tsclient (there is nothing to display however)
thank you for your help
bcarme95 wrote: Wed Apr 03, 2019 11:06 am 3. Yes i have access, i can't see usb key and i have access to \\tsclient (there is nothing to display however)
If you can't see your usb key connectiong from mstsc.exe, something is wrong with your server.
bcarme95
Post by bcarme95 »
Sorry i do a mistake :
3.Yes i have access, i can see usb key and i have access to \\tsclient (there is nothing to display however)
bcarme95 wrote: Wed Apr 03, 2019 3:34 pm 3.Yes i have access, i can see usb key and i have access to \\tsclient (there is nothing to display however)
Where do you have access? All redirected disks MAY (and may not) be displayed in My Computer/This PC/how-microsoft-call-it-in-your-windows and ALWAYS MUST BE displayed in \\tsclient
