I'm currently trying to redirect my Canon Scanner via usb redirection to my Windows Server 2016. I already tested SaneTwain. It works, but I can't use the scanner with my program (it requires a local scanner) so I'm forced to use USB redirection.
I tried redirecting my scanner using usb = xxx. Windows Server 2016 lists the scanner under 'My devivces' and installs drivers (takes some time). Every single time I restart my WTware the same process happens: TS sees a new device and installs a new driver.
Even tho the scanner (with correct model number) is listed and marked as 'operational' I'm not able to scan.
I attached a log.
CanoScan Scanner RDP redirection
- Logscanner.txt
- (48.76 KiB) Downloaded 1626 times
Re: CanoScan Scanner RDP redirection
Change power adapter. There are several "Under-voltage detected!" in log.
Is this scanner redirected with USB redirection in mstsc.exe?
Also, try VirtualHere USB redirection: viewforum.php?f=27
