Wtware on B+ / no option to install wtware for x86 in latest wtware
jazzldazzl
Post by jazzldazzl »
Dear all, I´m using "wtware for x86" to install with on an sdcard for Pi3b, but it only appears as an option during installation on my desktop if using the 5.6.24 version.
Now I have Pi3B+ and the 5.6.24 version no longer gives me something that works: I simply get a black screen on my monitor, nothing else. Checked 5 mins later, still the same.
So I´m hoping that latest version will do the trick, but how can I get it to show "wtware for x86" during installation on my windows desktop, and is it possible that it´s not even the wtware version being the reason for my issues? Maybe some extra stuff that needs to be configured in the old WTware version when it´s used on a B+ model?
I tried all versions between 5.6.24 and the latest as well, but theyre also missing "wtware for x86".
Re: Wtware on B+ / no option to install wtware for x86 in latest wtware
Press here:
jazzldazzl
Thanks, will try this tomorrow!
aaronouthier
Post by aaronouthier »
Raspberry Pi’s don’t have x86 processors, so an x86 bootable SD card would be useless in a Pi. Pi’s have an ARM CPU, similar to what is used in most Android tablets.
jazzldazzl
Thanks! Got it, that all makes good sense of course but I thought that for some reason the x86 option should be available since there´s a guy in a youtube video who checks that during the installation. Anyway, all works good now in latest version!
