6.0.34 - h264 hardware acceleration on Raspberry
Features, errors, comments and problems of specific WTware versions.
h264 AVC444 hardware acceleration. For now works only for Raspberry, because on Raspberry it's uniform. Later will be for x86.
All graphic is compressed by the same codec, not only video.
It noticeably lods server processors.
In WTware is turned on by default. If won't draw correctly, turn it off by "graphic=disable-h264" in terminal config.
On servers is turned off by default. Turn it on manually, in gpedit.msc:
