I have one users at a clients location that keeps saying they get:
“I’m tired” or
“Main Pipe Closed” or
“GFX Pipe Closed”
on their raspberry pi 4 terminal I checked out the logs and I do see these errors happening but they state that it's due to an internal error and to contact WTware support. to me it looks like the sound settings I had may have been the issue so I've removed those parameters to test. If anyone can take a look at the attached logs though I would really apricate it.
GFX Pipe Closed and Main Pipe Closed Errors
- WTware_DC.A6.32.4B.06.3D_2021-03-02_08-38-52.txt
- (104.93 KiB) Downloaded 763 times
Re: GFX Pipe Closed and Main Pipe Closed Errors
There are no errors in this log. I need log intermediately after the error appears to find error reason. Do not reboot: log in memory will be lost. You may start logging, and terminal will send log to configurator until you close configurator application or reboot terminal.
