Lenovo Thinkpad and Synaptics Touchpad
Good morning.
In my RDS enviroment, we are introducing some laptops.
System does'nt recognize the touchpad (Synaptics) meanwhile it recognizes the Elan Trackpoint.
It could be that there's no driver?
It's possible to introduce it?
I attach the log file.
Paolo
Paolo
- LENOVO log file.txt
- (172.83 KiB) Downloaded 3951 times
Re: Lenovo Thinkpad and Synaptics Touchpad
It is possible to add driver if we know which one to add. There are too many chips and drivers...
1. Please try the latest wtware version and show me the same log. It should dump some more information about input devices.
2. If some other linux works with this touchpad, run:
And show me 1.txt file
PS: "extra=WTFW_i915_adlp_dmc_ver2_16.bin.zip" does not work for firmware. Write "firmware=WTFW_i915_adlp_dmc_ver2_16.bin.zip" instead of extra=
sudo dmesg > /tmp/1.txtPS: "extra=WTFW_i915_adlp_dmc_ver2_16.bin.zip" does not work for firmware. Write "firmware=WTFW_i915_adlp_dmc_ver2_16.bin.zip" instead of extra=
I've done the update.
I set up all the firmwares needed.
I send the new log.
I don't have a linux installation working, but if I could make a setup to find a path.
Is there a preferred version? Ubuntu?
I send the new log.
- WTware_log_240624.zip
- (36.46 KiB) Downloaded 4037 times
I've done the setup of the Debian 12.
Without installing all the system, I got the log of the bootstrap.
I send it in attachments.
- log-1.txt
- (62.32 KiB) Downloaded 4024 times
Here the log
- log2.txt
- (3.98 KiB) Downloaded 3935 times
Ubuntu, yes.
Also, why are you sure there is Synaptics touchpad? Recognized the Elan Trackpoint does not work, no reaction at touchpad?
PS: physical display mode is "display=1920x1200". With "display=1600x900" image on screen becomes smooth. Perhaps, those two lines will make fonts large enough with clear picture:
display=1920x1200
scale_factor = 125Re: Lenovo Thinkpad and Synaptics Touchpad
Trackpoint works, and also the buttons left/right of the touchpad.
On another identical laptop there's a Windows 11 OS. It recognized the touchpad as a synaptics
Please try this build: http://wtware.com/testing/202407020123/ ... .29.en.zip
IT WORKS!! the pad respondes.
But the movement is very slowly. For each total-pad move, it moves on the screen about 1 cm
1. Write into config:
2. Show me log after reboot and some movements.
mouse_accel_mult=16Re: Lenovo Thinkpad and Synaptics Touchpad
I set the parameter "mouse_accel_mult=16".
But now, the other mouse I attached and the trackpoint are gone crazy.
I send the current log.
- WTware_D4.E9.8A.5B.C2.78_2024-07-02_11-59-44.zip
- (40.76 KiB) Downloaded 3870 times
Please try 6.2.30 version from https://wtware.com
Now it should understand:
For touchpad only, not for mouse.
mouse_accel_mult=touch:12Re: Lenovo Thinkpad and Synaptics Touchpad
I put on the new version and all works well.
I deleted the mouse_accel_mult parameter. It's works fine.
Thankyou very much!!! You're the best!
