Battery Level Display/Overlay
twolifestyles
Post by twolifestyles »
We use this at work for a few laptops. There is no way to check battery level and they have gone dead multiple times.
Can a battery level indicator be added to the login screen and maybe an overlay as well in the popup?
Re: Battery Level Display/Overlay
Will be done in the next version on connections menu screen, wtware login/password screen and popup window. Will display battery level image only if works on battery and battery level is less than 100%. No image on charger. Correct?
Please try 6.2.64 wtware version.
