I can't seem to get this camera to work. It does work using RemoteFX using a Windows client. When running the WTware terminal it does display the USB ID and the full device information in the web page. The VM is a Win 10 Pro under a Windows 2016 server.
I added the following into the config file, then restarted the unit. Still no luck
usb=045e:0772
Microsoft LifeCam
Microsoft LifeCam
- WTware.log
- (27.23 KiB) Downloaded 2227 times
Re: Microsoft LifeCam
Please, try this build:
http://pxe.ru/files/testing/201708151356.zip
And press link on "[0]" near USB ID at your screenshot. It will display a lot of information about device. Show it to me.
Attached is the terminal log after upgrading to .13 and the USB info you asked for. Still did not work after upgrading to .13
- WTware-usb.txt
- (62.67 KiB) Downloaded 2090 times
- WTware-13.txt
- (24.88 KiB) Downloaded 2153 times
Write to config:
usb=045e:0772,debug
And show me a log. Log will be veery large, so please don't do unnecessary things. Boot, get error, save.
PS: 65Kb of usb device description is a pain. Not sure we will run it...
usb=045e:0772,debug
Anything new on this? Getting the camera working would be a huge plus for us.
I also have 2 scanners that aren't working, but the USB info for those 2 are much smaller. WTware recognizes them and displays all of their info.
