Microsoft LifeCam
revo1059
Microsoft LifeCam
Post by revo1059 »
I can't seem to get this camera to work. It does work using RemoteFX using a Windows client. When running the WTware terminal it does display the USB ID and the full device information in the web page. The VM is a Win 10 Pro under a Windows 2016 server.
I added the following into the config file, then restarted the unit. Still no luck
usb=045e:0772
WTware.log
(27.23 KiB) Downloaded 2226 times
Re: Microsoft LifeCam
Please, try this build:
http://pxe.ru/files/testing/201708151356.zip
And press link on "[0]" near USB ID at your screenshot. It will display a lot of information about device. Show it to me.
revo1059
Post by revo1059 »
Attached is the terminal log after upgrading to .13 and the USB info you asked for. Still did not work after upgrading to .13
WTware-usb.txt
(62.67 KiB) Downloaded 2089 times
WTware-13.txt
(24.88 KiB) Downloaded 2151 times
Write to config:
usb=045e:0772,debug
And show me a log. Log will be veery large, so please don't do unnecessary things. Boot, get error, save.
PS: 65Kb of usb device description is a pain. Not sure we will run it...
revo1059
Post by revo1059 »
See attached
WTware-usb2.txt
(195.48 KiB) Downloaded 2243 times
revo1059
Post by revo1059 »
Anything new on this? Getting the camera working would be a huge plus for us.
I also have 2 scanners that aren't working, but the USB info for those 2 are much smaller. WTware recognizes them and displays all of their info.
