Posts: 65 Joined: Fri Sep 29, 2017 6:43 pm
Post
by geefox » Wed Dec 06, 2017 4:12 pm
today on one client there was an error which caused an disconnect from the rds session.
wtware version 5.6.22 is installed on an x86 client on harddrive
I've attached the whole logfile
best regards,
thomas
[rdpclient 1102] [53790.688600] Enable font smoothing and Desktop Composition.
[rdpclient 1102] [53790.834384] GFX codec.
[rdpclient 1102] [53791.780238] rdpclient-vchan-drdynvc.cpp ( 480): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpclient 1102] [53791.780738] rdpclient-vchan-drdynvc.cpp ( 480): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpclient 1102] [53791.781147] rdpclient-vchan-drdynvc.cpp ( 480): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpclient 1102] [53791.781596] rdpclient-vchan-drdynvc.cpp ( 480): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpclient 1102] [53791.781619] ./streamInOps.h ( 313): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpclient 1102] [53791.781632] ./streamInStealer.h ( 29): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpclient 1102] [53791.781644] [ERROR] totalLength 29783 large then packet 20 channelId 1003.
(205.49 KiB) Downloaded 1175 times
Posts: 972 Joined: Fri Dec 03, 2004 2:05 pm
Post
by aka » Wed Dec 06, 2017 6:55 pm
It is the same problem as in
viewtopic.php?f=23&t=48234
Tell me all changes you made to encryption so that I could reproduce error on my stand, and I'll try to fix it.
Or, if it is possible, let me to connect to this server from internet.
Post
by geefox » Thu Dec 07, 2017 10:42 am
sure, its possible to connect to this server. do you have any kind of phone number or skype?
when do you have time?
Post
by aka » Thu Dec 07, 2017 4:05 pm
Skype: wtware, Andrey Kovalev
Post
by aka » Tue Dec 12, 2017 9:34 pm
I found the source of this error. You turn on FIPS encryption. FIPS is paranoid mode for old-style native RDP encryption. WTware didn't support it before and there is no reason to support it now, when RDP can work over SSL/TLS.
Find and turn FIPS off. It is default setting for all Windows Servers. Here should be DISABLED:
And there should be no "FIPS" anywhere:
Turn On SSL/TLS in "Require use of specific security layer" to disable old-style RDP encryption.
Post
by geefox » Wed Dec 13, 2017 12:45 pm
just configured this settings you mentioned. keep you informed if anything changes/happens
thank you very much
Post
by geefox » Wed Dec 13, 2017 3:14 pm
hey, tried to find a difference in the log files - here it is. - hopefully this is the solution
old login with FIPS enabled:
[rdpclient 3001] [676561.152498] TCP: connecting to 10.100.101.210:3389.
[rdpclient 3001] [676561.157147] TCP: connection with 10.100.101.210:3389 established.
[rdpclient 3001] [676561.157345] Turn keepalive on.
[rdpclient 3001] [676561.157438] Free ram after buffers allocation: 913252 KB.
[rdpclient 3001] [676561.167765] Server supports GFX Pipeline.
[rdpclient 3001] [676561.173413] Process RDP server certificate.
[rdpclient 3001] [676561.173505] RDP5 encryption (X.509).
[rdpclient 3001] [676561.198718] Timezone '(UTC+01:00) Amsterdam, Berlin, Bern, Rome, Stockholm, Vienna'.
[rdpclient 3001] [676561.198878] Enable font smoothing and Desktop Composition.
[rdpclient 3001] [676561.460304] GFX codec.
and then with FIPS disabled and forced to use SSL/TLS
[rdpclient 3008] [676562.503729] TCP: connecting to 10.100.101.203:3389.
[rdpclient 3008] [676562.507117] TCP: connection with 10.100.101.203:3389 established.
[rdpclient 3008] [676562.507247] Turn keepalive on.
[rdpclient 3008] [676562.507326] Free ram after buffers allocation: 913808 KB.
[rdpclient 3008] [676562.507405] Empty Balance Info.
[rdpclient 3008] [676562.514422] Reconnect with TLS/SSL enabled.
[rdpclient 3008] [676562.514514] TCP: reconnecting to 10.100.101.203:3389.
[rdpclient 3008] [676562.517183] TCP: connection with 10.100.101.203:3389 established.
[rdpclient 3008] [676562.517270] Turn keepalive on.
[rdpclient 3008] [676562.517363] Empty Balance Info.
[rdpclient 3008] [676562.530119] Server supports GFX Pipeline.
[rdpclient 3008] [676562.530227] TLS.
[rdpclient 3008] [676562.530307] SSL/TLS.
[rdpclient 3008] [676562.559736] Redirected Session ID 0x00000000.
[rdpclient 3008] [676562.587074] Timezone '(UTC+01:00) Amsterdam, Berlin, Bern, Rome, Stockholm, Vienna'.
[rdpclient 3008] [676562.587189] Enable font smoothing and Desktop Composition.
[rdpclient 3008] [676562.591720] RDP5 encryption (X.509).
[rdpclient 3008] [676562.762692] GFX codec.
Post
by geefox » Wed Jan 03, 2018 4:05 pm
hi,
again we discovered an error with the x86 and RPI 3 clients.
i've attached the logfile in a zip file because it seems its too big for uploading directly
error.zip
(54.87 KiB) Downloaded 1006 times
Posts: 703 Joined: Mon Jan 17, 2005 6:30 pm
Post
by akatik » Wed Jan 10, 2018 6:50 pm
FIPS encryption at 10.100.101.210. The same as before.
Broken sound configuration. "sound=on, amixer:cset numid=3 1" - it's from Raspberry world.
There is no RPI3 log, only one x86 log.
Post
by geefox » Tue Jan 16, 2018 12:22 pm
also disabled FIPS on the rds broker and removed the sound line from config
going to try this now, and will give you feedback
