UEFI Error: Failed to mount boot media
laesyar
Post by laesyar »
When I try to install WTware 6.0.46 from USB with UEFI, the following error is displayed:"
ERROR: Failed to mount boot media. Please, send the photo
of this screen to WTware techsupport and describe:
where do you boot terminal from and what makes
you think, that terminal can boot from it.
It worked fine on the same laptop with WTware version 6.0.24.
Legacy boot works fine with WTware version 6.0.46.
laesyar
Re: UEFI Error: Failed to mount boot media
Post by laesyar »
Additional information from all.log:
[initrd] bootWay.cpp (132): -- ERROR -- Failed to mount /bootmedia
[initrd] bootWay.cpp (198): -- ERROR -- INTERAL ERROR. Please, contact WTware tech support.
[initrd] bootWay.cpp (251): -- ERROR -- INTERAL ERROR. Please, contact WTware tech support.
Show me FULL all.log
laesyar
Post by laesyar »
aka wrote: Thu Apr 22, 2021 7:07 pmShow me FULL all.log
I want to, but then I have to take a lot of photos.
It goes to CLI after the error message, web interface does not work.
I used less /tmp/all.log to view the log file.
https://wtware.com/logs.html
Take USB flash, common, small capacity, without passwords, without encryption.
Format it. File system must be only fat32, others won't work.
Connect newly fat32 formatted flash to terminal.
From terminal command line run command:
log
Wait for half a minute. On the screen you may see errors, it's ok. Make photo of the screen and attach photo to e-mail.
Eject USB flash. Connect to windows computer. On this flash should be file all.log.
laesyar
Post by laesyar »
Unfortunately that also doesn't work
Please try 6.0.50 wtware version.
laesyar
Post by laesyar »
It works good now, thanks!
