Change the font color?
Re: Change the font color?
Please try this:
http://wtware.com/testing/202002220938.zip
In config:
menu_colors=00ff00,ff0000
Sorry, I didn't test configurator :(
Write value in "Text" tab. It will display errors, but save config.
nicktheclick
Post by nicktheclick »
Hello
I'm using WTware 5.8.90/RPi on a RB PI 4.
Everything is working fine (openVPN, RDP, etoken) but as I'm "fine tuning" the installation I'm having problems with this parameter.
I'm configuring the RBPI straight from the configuration menu on the device.
Any suggestion ?
Nick
nicktheclick wrote: Mon Mar 16, 2020 6:43 pm I'm using WTware 5.8.90...having problems with this parameter.
Because it's in 5.8.91. Use the link above or today's build: http://wtware.com/testing/202003161523.zip
nicktheclick
Thanks a lot. I'll try it ASAP.
Ciao !
Nick
nicktheclick
Works just perfect !!!
Thanks !!
